sight picture (over the nose)
Postby BRS » Sat Jul 29, 2023 9:21 pm
My sonex is the first and only one that I've flown in. I was wondering if the nose sight picture, on others, is like mine in level flight. Can't really see a thing in front of me (I'm 5'10) when sitting in the middle seat (between the cushons) and flying straight and level.
First Pic, view at apx level attitude with camera held at eye level (bumpy day)
Click to see full image
Second Pic, slight desent (170 fpm shown)
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Re: sight picture (over the nose)
Postby Bryan Cotton » Sat Jul 29, 2023 11:27 pm
Same issue here
Postby daleandee » Sun Jul 30, 2023 12:43 am
Higher airspeed will bring the nose down a bit. Mine looks about like your second photo but when I fill the tank and the CG is forward I can feel it and see it ...
Dale
3.0 Corvair/Tailwheel
daleandee
Postby XenosN42 » Sun Jul 30, 2023 9:41 am
The sight picture from my OneX is about the same.
-- Michael
OneX N169XE
XenosN42
Postby builderflyer » Mon Jul 31, 2023 9:49 am
Brock, to me your top photo looks like my Sonex nose in a climb. In your bottom photo, the nose looks to be a little high for a normal cruise. That's sitting in the left seat, standard, not lowered.
Art,,,,,,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,,,Jabiru 3300 #261
builderflyer
Postby jaflint » Mon Jul 31, 2023 12:07 pm
I second Art’s observation, from a lowered left seat pilot perspective.
Jason Flint
Sonex #1655
3.0L Corvair
1200+ hours
2600+ landings!
jaflint
Postby BRS » Mon Jul 31, 2023 10:46 pm
jaflint wrote:I second Art’s observation, from a lowered left seat pilot perspective.
Well then, I might just have to try flying from the left one of these days. Have only flown from the center thus far. Might just double check the flaps rigging, after taking another picture while in smooth conditions.
Thanks for all the input.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Postby sonex892. » Tue Aug 01, 2023 12:20 am
As Dale mentioned the higher the speed the lower the nose. I fly a 3300 Jab and it is noticably higher on the nose when flying at 100kts compared to 130kts. So probably cant really compare the sight picture of a 120 HP plane to an 80HP plane.
If you think it is higher than normal. You could check the rigging instructions in the plans and double check your wing incidence is correct and also check the ailerons and flaps are set up correctly
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby gammaxy » Tue Aug 01, 2023 12:35 am
I fly from the left with a 80 HP Sonex A. My headset occasionally bumps the canopy. Definitely would consider a center stick and fly from the middle solo if it worked with the lowered seat. My sight picture is much closer to the second picture than the first. The first seems closer to what I see when I'm climbing at 70-80mph. I typically lower my nose to where I can see the horizon and for engine cooling once I'm around pattern altitude. All this could just be that my eye level is a little higher, but I don't feel like I sit particularly tall (I'm about 6'1" though).
Chris Madsen
Aerovee Sonex N256CM
Flying since September 2014
gammaxy
Postby rbarber » Tue Aug 01, 2023 9:48 am
All up weight and CG location will effect this too...
R.
N157SX, J3300
rbarber
Return to Sonex
