Aerovee oil Temps
Re: Aerovee oil Temps
Postby 429TB » Mon Jul 17, 2023 10:35 pm
Good news and bad news.
Good news is I've flown the aircraft 3 times and never saw oil temps above 200. Ambient air temps were 85 to 90. Thanks for the help everyone. I'm running a bottom mount oil cooler, swapped the oil springs from aftermaket springs i assume to OEM, insulated the oil temp sending wire and removed the old setup.
Bad news is, I have an oil leak that isn't very easily identified. It looks like rear main seal area to me. I have been reading alot on here about the infamous dry aerovee and will strive for that. This leak isn't a small one. I have about 5 to 10 drops on the ground by the time I shut down. Get out and walk around.
Again, thanks for all the help everyone. Hope to fly it to Reklaw this year. Oshkosh is out unfortunately
429TB
Postby Bryan Cotton » Mon Jul 17, 2023 11:52 pm
429TB wrote:I have about 5 to 10 drops on the ground by the time I shut down. Get out and walk around.
Stop bragging! I'm sailing the Exxon Valdez here.
Postby 429TB » Tue Jul 18, 2023 8:52 am
I guess on the bright side the oil is always fairly new when you have to add a quart after 2 hrs of flight.... h
429TB
Postby Bryan Cotton » Tue Jul 18, 2023 9:26 am
That sounds worse than 5-10 drops. For me it's generally 1/2 quart per 10 hours. Still, it will never rust.
Postby 429TB » Tue Jul 18, 2023 9:57 am
Once my A&P is ready he and I will install the Duckworks LED landing lights, a new canopy (current one is cracked beyond repair) and I guess pull the motor to replace the rear main seal ... lots of fun! Sounds like a dead of winter project list ....
429TB
Postby Area 51% » Wed Jul 19, 2023 9:55 am
Take a good close look at the sealing surface of the flywheel. Stock VW flywheels have a ground surface, but the Aerovee flywheel is machined which can eat up a seal. I had a similar leak till I took my flywheel to a shop and had it resurfaced. .
Postby 429TB » Wed Jul 19, 2023 10:08 am
Area 51% wrote:Take a good close look at the sealing surface of the flywheel. Stock VW flywheels have a ground surface, but the Aerovee flywheel is machined which can eat up a seal. I had a similar leak till I took my flywheel to a shop and had it resurfaced. .
Thanks for the info! I will for sure do that when I pull it all apart.
429TB
Postby Bryan Cotton » Wed Jul 19, 2023 12:01 pm
I'll also throw in my thanks for that tidbit. I'll put it on the list of possible things to do for my major overhaul - working hard to get there. 122 hours and counting.
