by Bryan Cotton » Tue Jun 27, 2023 11:18 am
429TB wrote:What's your thoughts there ?
I would be checking the wiring. My sensor is an RTD, so the resistance changes with temperature. If you have a bad connection that could give fast resistance changes. The oil has a lot of inertia with respect to changing temperature, so I doubt it is actually changing that fast.
Edit: I also had to run a dedicated sensor ground from the RTD to my Alpha MFD, else my temps would change with electrical load.
