GraemeSmith wrote:I've had to rectify similar at 400 hours when the aileron bellcrank bearing in the wing started to wear and develop slop in the bearing - which also transmitted to the hinges.
If those are the "stock" roll formed hinges - then it looks like the "roll" has opened up some. A reason some folks use the forged hinges.
Couple of things I would look at. Is it a "uniform" opening and they could ALL be gently squeezed tight again. Or is it just some - and you might have a bit of an alignment issue?
If the slop is by the actuating arm where the bellcrank/pushrod are pushing on the end of the aileron - that needs resolving. You have introduced some flex on the axial line of the hinge pin. That will allow wear to accelerate.
In any event - that is "slop" in the control system before you even get in the air. As presented in the videos - at a Condition Inspection my AP would "fail" those hinges for being worn out......
Murray Parr wrote:I should be able to squeeze them a bit tighter, I am really surprised they have this much play in them as I drilled and riveted them with the hinge halves together and upon assembly, the pins installed without much effort.
Can anyone comment on the forged ones as to how much better they are and where to source them?
Murray Parr wrote:Can anyone comment on the forged ones as to how much better they are and where to source them?
MS20001P aluminum hinge is extruded. The closed hinge loops cannot be pulled apart. Furnished with hinge pin. Anodized finish.
daleandee wrote:Can you order a larger wire size for the piano hinge?
Dale
Corvair 3.0 / Tailwheel
Users browsing this forum: No registered users and 22 guests
