Skippydiesel wrote:- if asked outright (as happened) I give a truthful answer.
Skippydiesel wrote:Problemo! -
The few installations I have seen with the double/forward coolant radiators, have been aftermarket fuel injected 912 variants - mechanical fuel pump is redundant/deleted.
I will not be removing my fuel pump any time soon - this pretty much makes what I saw as being quite a straightforward installation way more complicated on the right side of the gearbox. - Such is life & homebuilt aircraft!
peter anson wrote:For supply of small radiators in Australia, how about heater core units from a small car? They should be pretty cheap from wreckers. I don't know if any are a suitable size but it's worth looking. My guess is that you would also need to make a small reservoir/header tank.
Nick wrote:I have been reading all the posts about cooling issues (liquid) on Sonex Aircraft. If I may add my two cents. I believe the people having issues are with Rotax engines. I am building a Waiex Legacy with Jabiru 3300 with Liquid cooled heads. So I too have looked at where to put the Radiator. I opted for the back for now. Anyway for those looking for solutions I just want to add to look at Jabirus with LCH for another variation.
Users browsing this forum: Google Adsense [Bot] and 2 guests
