Skippydiesel wrote:Kai wrote:I had my twin radiator setup especially made in the Check Republic- ordred them through Edge Performance:
I thought Edge/Thomas Hauklien was in Norway - I have emailed him about the double radiator installation in his Sonex
The oil cooler is the largest $$$$$$€€€€€€€ Rotax 912-series type.
As is mine - I am beginning to wonder if mine has some sort of internal restriction, it should do better than 110C.
there must be an oil thermostat in my future-
I have an unused (never had oil through it) one - happy to exchange it for a nice pair of radiators :)
Skippydiesel wrote:Hi Kai,
Do you have contact details for the Czech builders of your radiators?
AND
Photos of your cowling showing air in/out?
Skippydiesel wrote:So far, I have had a flat refusal on the grounds of not being insured for aviation work (?????) -
daleandee wrote:Skippydiesel wrote:So far, I have had a flat refusal on the grounds of not being insured for aviation work (?????) -
Many moons ago I owned a Quad City Challenger 11 CWS that used a Gates PowerGrip GT2 belt for the redrive. When you ordered one or went in to pick it up you never said what it was for. Many used the term "airboat" for the same reason you mention.
On my Sonex I wanted the fiberglass spinner to be chromed. I found a few companies that could do it but all said "absolutely not" if it's part of an aircraft.
