DCASonex wrote:On an A series Sonex with flap lever on left side, those stops will make a very noticeable improvement and well worth the investment.
Once you get the stops adjusted where you want them, might consider using the final dimensions to make solid stops that contact a broader area near the top edge of the flaps. The small bolt heads of the adjustable stops contact a relatively soft area on the flap and I was concerned about possible cracking of the aluminum. Solid stops can be made from firm plastic or even wood.
Users browsing this forum: flyguy0609 and 24 guests
