PFH Sonex B
Re: PFH Sonex B
Postby pfhoeycfi » Sun Jan 22, 2023 1:22 pm
With my flaps set back to spec and a 6.5" length of 1/4 Dia drinking straw taped under the right aileron, left roll tendency is gone and I can fly handsoff. 6.5" was my first try. I make a small tab based on that.
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: PFH Sonex B
Postby Bryan Cotton » Sun Jan 22, 2023 1:39 pm
pfhoeycfi wrote:With my flaps set back to spec and a 6.5" length of 1/4 Dia drinking straw taped under the right aileron, left roll tendency is gone and I can fly handsoff. 6.5" was my first try. I make a small tab based on that.
Flying solo of course. Do you have a center stick? I found that when in trim for two up, it would roll left from the left side and right from the right side. Not by much.
Re: PFH Sonex B
Postby pfhoeycfi » Sun Jan 22, 2023 1:52 pm
Yes center stick. I should have also said I was flying from the middle...which is more comfortable for me. I suspect when I try from the left again it will roll a bit in that direction.
Peter Hoey
pfhoeycfi
Re: PFH Sonex B
Postby pfhoeycfi » Sun Jan 29, 2023 1:53 pm
Flight number 5 today. I've noticed over the past 2 flights that the number 4 CHT is significantly cooler than the others. Typically #4 is 20 deg to 30 deg cooler than the max. 1, 2 and 3 are always within 5 or 6 degrees of each other, 3 always the hottest. RPM and MP are good. For example...in order... 356, 355, 358, 322. The #4 EGT is not the coolest. At what point is the difference a concern, if at all.
Peter Hoey
pfhoeycfi
Re: PFH Sonex B
Postby pappas » Sun Jan 29, 2023 8:42 pm
If your temps always stay where you see them now, you should be a very happy boy! EGT isn't actually very important. CHT's rule!
Lou Pappas
Phoenix, AZ
RV-7A (Building)
Waiex B Turbo
RV-8
Waiex Legacy 3300
Hiperlight SNS-9
Falcon Ultralight[/b]
pappas
Re: PFH Sonex B
Postby BRS » Mon Jan 30, 2023 12:30 pm
pappas wrote:If your temps always stay where you see them now, you should be a very happy boy! EGT isn't actually very important. CHT's rule!
Revmaster places an EGT limit of 1400˚F. Does Aerovee have such a limit? Seems to be a matter of what the exhaust valves are made of. Lycoming does not have a limit on EGT as certified engines have more robust valve designs. So in my case, at least, I'd say that EGT IS important as far as maximum limits.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Re: PFH Sonex B
Postby builderflyer » Tue Jan 31, 2023 10:47 am
Jabiru also places EGT limits on their engines........1256 degrees when over 70 % power, for example on my 3300. It may be best to ignore Busch's advice unless flying behind a Continental or Lycoming engine.
Art,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,Jabiru 3300 #261
builderflyer
Re: PFH Sonex B
Postby pfhoeycfi » Wed Feb 08, 2023 10:07 am
Peter Hoey
pfhoeycfi
Re: PFH Sonex B
Postby Bryan Cotton » Wed Feb 08, 2023 10:17 am
Nice! I should do a writeup for Sport Aviation.
Re: PFH Sonex B
Postby pfhoeycfi » Wed Feb 08, 2023 10:53 am
Bryan Cotton wrote:Nice! I should do a writeup for Sport Aviation.
You should... EAA has a "What our members are building" form on their website. You can choose a long or short format... I went short. EAA said they would let me know when they will include it. Kitplanes was even easier. I just sent a short paragraph and a few pics to editorial@kitplanes dot com and they had it posted in a few hours.
Flight # 7 this morning,
Peter Hoey
pfhoeycfi
Return to Sonex-B / Waiex-B
