Securing Electrical Conduit
Postby lakespookie » Tue Jan 31, 2023 9:16 pm
I am piping some Tubing through my wings in order to have more servicible wiring but i am kind of trying to figure out a good way to secure the tubing, the current plan is to oversize the tooling holes and use some plastic bushings/grommets but i have concerns that the tubing i use will walk in the grommets. Its probably a dont care in the grand scheme of things as it can only go so far given the wires that will be in it and the connections with seal all connectors. That being said what have others done to route or secure tubing used to route wire in the wings.
Jill's Build Log
PPL-ASEL
Tail = Complete
Wings Closed Out = 02/04/2024
Waiex-B 0054
Panel G3X
lakespookie
Re: Securing Electrical Conduit
Postby Bryan Cotton » Tue Jan 31, 2023 10:19 pm
I used polypropylene tubing, and it's a snug fit in the holes. Seems pretty secure to me.
Postby dbdevkc » Wed Feb 01, 2023 4:01 am
I used some tubing I got from Aircraft Spruce. It is very thin walled, so it’s actually looser in the tooling holes than I expected. What I did was put a zip tie around it on the outboard side of rib #17 so the tube itself can’t slide inboard, and a zip tie on it at the inboard side of the #1 rib, so the tube can’t slide outboard. Also, doing it that way I could always remove both zip ties and remove the tube in the future if I ever need to - not that there ever should be reason to do so I can imagine.
I did not use bushings/grommets.
[color=#800000]Kevin Conklin
Building Waiex #169
dbdevkc
Postby lakespookie » Wed Feb 01, 2023 3:48 pm
Got ya yeah my plan is propelyne tubing through gromets in the tooling holes that i am oversizing, honestly the only reason its a concern is that i have to segment the pitot tube side since i am installing a regulated pitot tube. Probably a dont care i was thinking of using the zip tie method i was just worried about the zip tie potentially walking.
Jill's Build Log
PPL-ASEL
Tail = Complete
Waiex-B 0054
Panel G3X
lakespookie
Postby dbdevkc » Wed Feb 01, 2023 10:48 pm
dbdevkc wrote:... rib #17 ...
Haha. that would be #12.
Building Waiex #169
dbdevkc
Postby Area 51% » Thu Feb 02, 2023 7:55 am
After I got the tubing through the tooling holes, I warmed up the ends and pushed a countersunk screw into the ends of the tube, flaring the tube so it can't come out.
Send me your email and I will send you a picture.
Area 51%
Postby lakespookie » Thu Feb 02, 2023 8:44 pm
Email Sent but that makes sense to me in my head. Although a picture will always help
And LOL to that Rib 17 i honestly read it as Rib 12 lol
Jill's Build Log
PPL-ASEL
Tail = Complete
Waiex-B 0054
Panel G3X
lakespookie
Postby RickA » Wed Feb 22, 2023 1:31 pm
I am well behind you, just working on the tail, but was contemplating conduit in the vertical tail for possible beacon and/or Avionixs before closing it up with the skin. Any suggestions on where to locate the conduit, … the leading edge, drill rib holes? Having not built the fuselage yet I am wondering where best to feed the conduit to avoid interference with fuselage structures etc. Any suggestions on how to secure the conduit being its vertical?
RickA
Postby lakespookie » Thu Feb 23, 2023 4:14 pm
In the wings the tooling holes just make sense but you could always do something similar to how the Pitot static lines are routed where you attach a tab that you then route the conduit through similar to how the pitot lines are routed. in the right wing i think its like page W21 or something in that area i cant really give you a good example since i am in a waiex, that being said the fuselage routing is the easiest part lots of space and options. If the vertical stab is built anything like the rudervators in the waiex you should have plenty of mouning options for either solution.
Jill's Build Log
PPL-ASEL
Tail = Complete
Waiex-B 0054
Panel G3X
lakespookie
Return to Electrical System
