Panther16 wrote:I have Tracy O’Brien brakes with the Hager stick mounted master cylinder lever assembly. It works well for me and has been on my Sonex for 420 hrs.
Panther16 wrote:I have Tracy O’Brien brakes with the Hager stick mounted master cylinder lever assembly. It works well for me and has been on my Sonex for 420 hrs. They hold well for run up and will raise the tail back off the ground if you get to aggressive on landing, I have a parking brake valve and it works well. The only thing they don’t do is allow you to spin around in front of to hanger.
Keith Rhode
Sonex 214 KE Jab 3300
daleandee wrote:Panther16 wrote:I have Tracy O’Brien brakes with the Hager stick mounted master cylinder lever assembly. It works well for me and has been on my Sonex for 420 hrs.
+1 on the Tracy O'Brien brakes and Hager stick master cylinder. Only complaint is that they can tend to fade quickly if you ask of lot from them for a long time. I usually use them enough to take the initial speed off the landing and then just let it roll on out ...
Bryan Cotton wrote:I ran mine through a grommet in the floor so I could run them down the gear leg. The fairing covers them. I have the Sonex hydraulic brakes.
austexaviator wrote:daleandee wrote:Panther16 wrote:I have Tracy O’Brien brakes with the Hager stick mounted master cylinder lever assembly. It works well for me and has been on my Sonex for 420 hrs.
Glad they work well for you. I have the hardest time bleeding that system properly. I am going with a reservoir style set up.
How did you route your brake lines?
