builderflyer wrote: was how the last part of your journey home was made in the dark of night. The hair still stands up on the back of my neck thinking about what an electrical failure (or engine failure for that matter) in a new to you experimental aircraft may have meant to the safe completion of the flight home. ...
GraemeSmith wrote:builderflyer wrote: ...
DMMS - Yes! In my legacy Sonex / Aerovee - I use 60KIAS at a maximum bank of 45 degrees holding altitude. If you let the nose fall through - you can pull it a bit harder - but I have a placard on the panel to remind me. "MMS - 60KIAS @ 45 Degrees"
BRS wrote:GraemeSmith wrote:builderflyer wrote: ...
Graeme, What is this DMMS you are referring to? I've never come across it before.
GraemeSmith wrote:
Murray Parr wrote:The best advice I ever got for engine failure at night was from my flight instructor who said, 'if the engine fails, glide to 50' AGL and turn the landing light on. If you don't like what you see, turn it off'....
Sonerai13 wrote:Murray Parr wrote:The best advice I ever got for engine failure at night was from my flight instructor who said, 'if the engine fails, glide to 50' AGL and turn the landing light on. If you don't like what you see, turn it off'....
That's what we always tell our helicopter students. "if you have to do an autorotation at night. Get your speed nailed, then turn on the landing light...." The rest is the same as your instructor's advice.
Users browsing this forum: Google Adsense [Bot], jaflint and 28 guests
