Onex107 wrote:Brian, the "catch can" really works. My home made one was a pint sized "Ball" jar, calibrated on the side in oz's. The standard top has a two pc. ring and center. I plumbed the center with plastic pipe fitting with a tube to the bottom of the jar. Drilled vent holes around the center fitting, tied a stainless chore ball under the lid to filter the vent holes, and mounted it on the fire wall with a large hose clamp. By loosening the hose clamp, I could loosen the jar ring and remove the jar. I recorded the volume of blow by in oz's. Compared to my Cessna O-200, the Aerovee is more like a car with oil consumption. The most oil blow by I measured was 10 - 12 oz in a 25 hr. oil change at 350 hobbs hrs. Whereas the O-200 "used a normal" quart in 10. The belly still gets dirty but it doesn't drip.
Bryan Cotton wrote:Steve,
Looks great, thanks for the response. Is it made of fiberglass? Hard to tell from the picture.
daleandee wrote:I purchased one of these for my Corvair but haven't needed it yet:
https://www.aircraftspruce.com/catalog/ ... eather.php
Users browsing this forum: Google [Bot] and 35 guests
