Scott Todd wrote:Peter, Since you agree with Kerry that the forces are pushing the horn down, could you draw a simple Free Body Diagram to show it? Anyone?
If its pushing down when mounted on top, then its also pulling down thru the bold head when mounted on bottom. The forces should be similar.
I can see a twisting moment imparted by the original push rod but I think the distance from the top to the bottom of the horn is negligible compared to the forces.
Scott
daleandee wrote:Scott Todd wrote:According to my plans (Onex 017) the horn does NOT go inside the rib but on the bottom, just like in the video.
Interesting ... I don't doubt what you are saying but I wonder why Sonex LLC would change from the way it is done on the Legacy aircraft. As I understood from Jeremy the OneX is just a Sonex that was downsized.
Can someone confirm how it's done on the new B model?
Curious ...
Users browsing this forum: Google [Bot] and 50 guests
