by mike.smith » Thu Sep 08, 2022 7:58 pm
I could use some collective brain power for my AeroVee.
Several weeks ago I suddenly, on one flight, began getting fluctuating oil pressure readings. Normally I run around 48 psi or so. I was getting readings that would stay up in the 40's, then suddenly drop to the low 20's. Then up into the 30's, etc. There was no rhyme or reason to the fluctuations. It stopped for a very short while after I polished the pressure relief valve plungers, but then came back pretty quickly. I've tried everything I can think of. Today I did my first run-up and taxiing after replacing the oil pump. I got the same fluctuations while taxiing, with readings as low at 17 psi.
Background:
- AeroVee 2.1
- 8 years old, 530 hours
- MGL Xtreme Mini
- No previous OP issues, ever
- Recent changes: none
I've tried all of these, with no change in behavior whatsoever:
- New OP sender.
- New wire from OP sender to RDAC.
- Replaced oil pump.
- Checked oil screen and pickup tube. Nothing there, and no obstructions in the tube (stuck a very long pipe cleaner up there).
- No oil leaks.
- Removed both pressure relief plungers. Polished the outside of the plungers, and polished the insides of the orifices. No obstructions or abrasions felt inside. Ground/polished anything on the springs that might possibly be grabbing. The springs are still incredibly strong (difficult to compress when reinstalling).
Unless there is something else I'm missing, my money is on the OP relief system, though I thought I've tried all the possible solutions, and don't know what else to try.
I suppose it's possible the RDAC could be bad, but everything else is nominal, so it would have to be a problem with just the OP in the RDAC. I'd ask MGL, but getting any responses from them these days is hit or miss, and mostly a miss.
I could put a manual gauge on the engine and run the engine with the top cowl off, but I really need to be able to taxi while watching the guage. You can't "just run the gauge into the cockpit" without cutting holes in things. If anyone has a solution, let me know. A guage with a long hose, taped to the windshield? What size are the threads for the OP sender? Anyone have a link to something suitable?
Any input would be appreciated.
