by n502pd » Wed Sep 07, 2022 10:54 pm
WOW!! Sure glad he found the damage prior to flight!! Since my field is a bit rough, I took carefull attention to the landing loads on the tail wheel spring 'jouncing' about, and made sure nothing hits anything, including the jamb nut. I have used several washers on both thru bolts to keep the hiem ends above everything. A longer rod was needed, and the thru bolt at the rudder horn is supported by a heavy duty large washer on the bottom and top, then assembled. simular at the tail wheel horn. So far, no damage, however. I will take the hint, and set it up on a saw horse and view everything on walk around., thanks for that hint!!!
Joe Nelsen
scratch built :D
Flying @78.2
KGYI/N. Tx Reg/Perrin Field
