Bryan Cotton wrote:I did a combination of hard line and braided line - all AN fittings. Documented on page 102 of my thread:
http://www.sonexbuilders.net/viewtopic. ... start=1010
Bryan Cotton wrote:We all have our preferences. Mine took many iterations and I would do the same thing again.
Skippydiesel wrote:It may not "age" as in corrosion but it can certainly fatigue and threaded caps can loosen.
I have little doubt at least some of the aluminium would also have been replaced.
Skippydiesel wrote:"hard line I was able to ensure the fuel flows downhill" - surely you make this point in jest.
Skippydiesel wrote:" not expensive" this is a comparative statement, so to what are you comparing the cost of your tube to? It cant be rubber hose, as aluminium tube & required fittings are many times the cost of rubber.
Skippydiesel wrote:In US dollars it doesn't look/sound expensive however your origional statement was one of comparison - where is the cost in rubber hose???
Bryan Cotton wrote:Skippydiesel wrote:In US dollars it doesn't look/sound expensive however your origional statement was one of comparison - where is the cost in rubber hose???
Aluminum hose fitting $5.80
Hose, 1' $2.95
Not sure what you would use to penetrate the firewall. I couldn't find anything at Aircraft Spruce. So the rubber hose stuff behind the firewall is $8.75 plus maybe $5 for a firewall connector so $13.75 vs $17.07.
I wasn't really making a comparison, but my hard plumbing is less than a tank of gas for my Yamaha.
