13brv3 wrote:I still have the normal handle that I haven't installed. The way I did the canopy frame rails left rivets in the way. I was going to make a new mounting block to avoid the rivets, but maybe the rear location would work. It looks like most of the assembly is the same, with some clever changes to the inside handle.
Rusty
peter anson wrote:The only differences are the internal handle parts although Tom found that the bulge of the Onex canopy meant he didn't have enough clearance on the outside and had to file down part of the external plastic trim, so I will supply them with a slightly longer shaft. If you already have an A model latch you just need the inside handle parts but you may have to make the same small mod.
Users browsing this forum: Google [Bot] and 92 guests
