by Rynoth » Fri Jan 10, 2014 2:51 pm
Bryan, go to plans page WIX-F21 and in the upper left of the page, highlight the 40" dimension for the width of the forward end of the aft fuselage. I'll explain below. You're probably a few weeks from this page but I want you to catch it.
For me everything fit together so great with the laser cut holes, it didn't bother me that it took a little bit of effort to slide in the upper vertical splice plates between the cross tie box and the upper longeron. I didn't pay enough attention to that 40" dimension and ended up with about 40.25" and a slight outward bow in my upper longerons at the front. The problem is a very small contact area between the front side of the cross tie box and the upper vertical splice plate. This contact area pushes everything slightly wider than it should be. A very small amount of filing (about 1/8" depth along a 1/2" edge of sheet aluminum) on that contact area on the cross tie box would have made everything come out correctly. What I'm describing will make more sense once you've made it to that page.
Coincidentally, I will need to do quite a bit of dissassembly in that area due to the recall of my upper horizontal splice plate and I'll have the opportunity to fix this.
Additionally, when making the cross tie box on WIX-F24, the plans don't show the hole patterns pre-drilled in the forward and aft sides of the box. I can't recall exactly how the holes appear on both parts, but the part that has 5? holes at each end needs to be mounted 1) to the rear and 2) with the holes closer to the bottom. Mine went in upside down and I got to drill new holes to fit the clips to the side skins.
