Flight control assemblies
Re: Flight control assemblies
Postby checkn6 » Sat Dec 22, 2012 6:00 pm
checkn6
Postby N111YX » Sat Dec 22, 2012 7:54 pm
How about just loosening the bolts a bit + some grease? The assembly is not going anywhere...:)
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1050 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby 142YX » Sun Dec 23, 2012 12:45 am
I tried going very loose on the bolts, but for my setup, just shy of what i would consider "too loose" ended up still being a bit tight for the tube.
I was over thinking everything until i thought of the hone - thats for sure. With the hone it took less than 5 minutes of tweaking to get a great fit.
450 hours and counting..
142YX
Postby EricS » Thu Jan 09, 2014 2:06 pm
Okay all,
I'm currently working on the control assembly and Waiex mixer. I've installed the 5/8" ID x 3/4" OD bushings in the control tree and have removed the powder coating from the control horns (SNX-C04-08). However, I still cannot push in the control horn due to a really tight fit. The plans say to line ream the bushings to obtain a "snug but freely rotating fit."
Any suggestions on what to use to line ream these bushings? I don't think they will need much, but it's a small enough diameter that it is hard to get sandpaper inside to ream them evenly.
Control Horns & Control Assembly Bushings
2014-01-08 22.14.24 (500x283).jpg (121.33 KiB) Viewed 6658 times
Eric Seber
Waiex #153
Jasper, Indiana
http://www.mykitlog.com/EricS/
EricS
Postby MichaelFarley56 » Thu Jan 09, 2014 6:26 pm
Sorry I can't help you more on this one Eric, but I believe the sandpaper thing is all I could figure out. I took a small sheet and rolled it up, put it into the brass bushing, and then just twisted it around for a while. If you do this, be careful though; I was able to get my passenger stick perfect with no slop, but my pilot side bushing is reamed a little too much and I have a little slop. Not enough to worry about, but one day I'll take it apart and replace those bushings and ream them again. That job is sort of a PITA so good luck! I'm sure there's a better way but I never could figure it out...
Sorry!
Waiex #0056 - N569KM
Jabiru 3300A #1706
Postby EricS » Thu Jan 09, 2014 9:24 pm
Mike, that is kinda what I figured. I don't really want to buy a 5/8" reamer just for that because it is such a small amount of material that needs to be taken off. But like you said, I just don't want to get any excessive slop in the system...if I can prevent it.
Thanks for the reply!
Eric Seber
Waiex #153
Jasper, Indiana
EricS
Postby saddler » Tue Jun 17, 2014 3:19 pm
I am starting on the control assemblies part of the build. I have read through this thread and appreciate the great info. I have everything fit and ready to drill. I don't want to rush this so thought I'd ask a question first.
How are you guys drilling for these taper pins? Is everybody spending the big bucks on the tapered reamers? I am building a Waiex so the plans call for the taper pin in the mixer assembly but thought I might put them in the control sticks as suggested in this thread. I just need some instruction on how to drill/install them.
Thanks!
Sean Saddler
Troy, OH
Waiex #165
First Flight 10/16/2015
https://www.facebook.com/Waiex165?ref=hl
saddler
Postby Sonex1517 » Wed Jun 18, 2014 8:50 am
You mean kinda like this....?
http://sonexfoundation.com/uploads/Seber_Taper_Pin_Installation.pdf
Chicagoland
N1517S reserved
325+ hours
Postby saddler » Wed Jun 18, 2014 9:38 am
Yep that's basically what I have found so far. Thanks for the info! For anyone that hasn't already found out, Aircraft Tool Supply has the reamer for $30 which is considerably cheaper than ACS.
Ordering now...
Sean Saddler
Troy, OH
Waiex #165
saddler
Postby Rynoth » Wed Jun 18, 2014 11:45 am
saddler wrote:Yep that's basically what I have found so far. Thanks for the info! For anyone that hasn't already found out, Aircraft Tool Supply has the reamer for $30 which is considerably cheaper than ACS.
Ordering now...
That's what I bought, though I haven't got to the point of using it yet. It sure looks like it will do the trick.
