by 13brv3 » Sat Mar 19, 2022 4:32 pm
For a hydraulic system like this, you need pressure, and fluid transfer. For disc brakes with the correct tubing and no air bubbles, there is essentially no fluid transfer so that can be ignored leaving only pressure. When we push on the master, we want to minimize our force, by maximizing the pressure. This is done with a smaller piston.
Say you push with 10 lbs of force on the master cylinder. If you have a larger piston with 2 square inches of area, then you generate 5 psi of pressure (10/2). If you have a smaller piston with 1 sq in of area, now you generate 10 psi (10/1). For the master, a smaller piston gives you more pressure for a given amount of force.
Since we aren't really displacing any significant amount of fluid with a proper brake setup, that one small piston can operate one or two brakes with the same force. Having dual masters gives you differential pressure, but no increase in brake force assuming the piston size isn't changed.
On the caliper end, we want to maximize force with the pressure we have available. If you have 10 psi of pressure available, you want the most piston area you can get (10 x total sq inches). For the caliper, more piston area (larger pistons, or more pistons) is stronger.
Of course there's a whole other layer of brake performance when you consider pads. Brake pad surface area and compound can make the difference between working well, and not working, even when the rest of the system stays the same. Nothing is ever simple.
Rusty
Rusty
Onex- Rotax 912 (150 hours and counting)
Fixed wing, gyroplane, A&P
