by 13brv3 » Mon Mar 14, 2022 5:42 pm
Greetings,
After two whole flights <g> on my 912UL Onex, the main thing I noticed is how much adverse yaw there is. Most of my time is in RVs and I was surprised how much more adverse yaw there seems to be in the Onex. The rudder is also very light and surprisingly effective. I wonder if this is all partly related to the small vertical stab?
Takeoffs and landings seem very honest for the tailwheel version. Stall "seems" (pending airspeed verification) lower than advertised, even though I have the short wingtips. The overall flying qualities seem very light and sporty.
The biggest issue is the brakes, which are terrible. The project already had the machined hub mechanical brakes when I bought it, so I thought I'd leave them. That seems like a mistake in retrospect. Basically they pulsate, squeak, and are too weak to hold for a proper runup. They also have a tendency to stick when they're on, though that could likely be fixed by rounding the corners of the actuator as they recommend. I'll have to replace these soon to keep from embarrassing myself, and also to be able to put the wheel pants on. I didn't bother installing those since I knew the brakes were going to be questionable.
My Dynon D180 has been misbehaving as well, and I may end up having to send it off for repair. Fortunately the EFIS side has been perfect, but the EMS side has been dropping out. It dropped my engine readings for minutes at a time on the first flight, but after pulling it out and verifying some wiring, it only lost readings for a few seconds at a time a few times today. If it can keep liming along, I may just order an MGL iEFIS MX1 and hope it gets here before the Dynon quits working.
Cheers,
Rusty
Rusty
Onex- Rotax 912 (145 hours and counting)
Fixed wing, gyroplane, A&P
