Stevetin wrote:Hello All,
My Waiex-A project came with the vertically split cowl years ago. Since then, Sonex came out with the horizontally split cowl and they indicate that "It's a must for the Aerovee engine". What are your thoughts and/or experiences with this?
Thank you!
Steve
wlarson861 wrote:I changed to the horizontal split cowl when I changed to a Jabiru. The vertically split cowl worked well but took time to remove or reinstall. The horizontal is great for access for most of the maintenance tasks except an oil change. For that I have to remove the bottom cowl. I can take the bottom cowl off by myself, but to reinstall it takes two people. Having had both, neither is better than the other in my opinion, just different. If I had either on hand I would install that one rather than buying a new cowl.
Users browsing this forum: No registered users and 79 guests
