pilotyoung wrote:I have a related question. I am adding nav/strobe lights to my Onex. I don't have any problem running the wires. My questions concerns how and where to connect them. I have shielded wire to keep the noise down and I have been told to only ground the shield at the grounding block. My fuse block and grounding block are on the right side of the inside of the fuselage. So do I run the wires from both wing tips to the grounding block and ground the shields there. Then run just the two hot wires, one for nav and one for strobe, to the switches and then back to the fuse block? If I do that, those wires will be unshielded. Will that short length of wire pick up noise?
Thanks.
