Aircraft Spruce call it a - Thermos Style Pressure Fuel Cap
Manufacturer Shaw Plugs call it a "SnapTite"
Part number 51019-4....2 inch
Strong smell of fuel in cockpit after fueling. Traced out whole fuel system from tank through firewall and vent system. No leaks. Was pretty sure I had not over filled and spilled into the dam around the filler and have it ooze into the cockpit. Smell went away after a little. Hmmm.....
Then I noticed the cap was a little looser when putting in in. Now I am fairly particular about keeping it on the setting and not using the "tighten/loosen" adjustment. But it was loose. Went to dial it tighter. That showed the rubber bung had cracked and failed under the compression plate. That would allow fuel to leak - especially from a full tank.
My original tank cap started getting too hard to properly seal after a couple of years, replaced and got about same life. Made my own cap similar to Peter's about the time he came out with his. Now just replace the O-ring every couple of years. Would also recommend getting Peter's will cost less than repeated purchases of the overgrown wine bottle stoppers.
