Wing stand/rack
Wing stand/rack
Postby Tony4aro » Thu Feb 10, 2022 2:48 pm
Hi All,
I found a thread that showed a wing rack... but the PDF of the plans is no longer supported. Does anyone have them, and can up load to this site? I know I can make them from the pictures I've found... but measurements would be good.
Corvair powered Waiex (under construction)
N3848D
W0181
Tony4aro
Re: Wing stand/rack
Postby N190YX » Fri Feb 11, 2022 4:59 pm
My wing stand/rack, which I got third hand from previous builder,s has dimensions of:
Bottom pan 3' X 7"
Vertical 2 X 4 height 5' 2" (2 X 4s going up at each end in the middle of the pan), with a 2 X 4 going across the length of the pan at the top of the vertical 2 X 4s
Tires are 10" with castoring on one end, very easy to move around and keep out of the way.
N190YX
Re: Wing stand/rack
Postby Area 51% » Fri Feb 11, 2022 7:00 pm
Re: Wing stand/rack
Postby pfhoeycfi » Fri Feb 11, 2022 7:07 pm
Here is the plans I found here a few years back. All credit to the name on the doc.
wing_stand_snx815_revA.pdf
(377.97 KiB) Downloaded 228 times
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: Wing stand/rack
Postby Tony4aro » Wed Feb 16, 2022 7:47 am
Thanks guys.... I really appreciate all the replies. If the weather holds out... I may go get my project on Monday. I'll post up some pics when I get it.
N3848D
W0181
Tony4aro
Re: Wing stand/rack
Postby mike.smith » Wed Feb 16, 2022 10:35 pm
That's the one I built. I still have it 12 years later. In fact, it's being used to hold a friend's Cessna wings right now!
Re: Wing stand/rack
Postby Tony4aro » Fri Feb 18, 2022 2:31 pm
Hi All.
I decided to do the "Sonex" version from the lower PDF. Just because it looked easer to do. I'm making a couple tweaks to it. Where the bolt holds the straps... I'm going to add a small D-ring so I can put a strap over the wings for a little added security when moving them around. BUT... to let people know... with today's inflation... it looks like it's closer to $100 for everything. $15 for the strap, $6 each for the casters (rubber 3") $7 each for the 2x4's, $17 for the 2'x4' ply (15/32") $8 per box for the screws. and the rest in Msc Hardware.
I'll post some pics after I get it built.
N3848D
W0181
Tony4aro
Re: Wing stand/rack
Postby Area 51% » Fri Feb 18, 2022 2:46 pm
Tony4aro wrote: with today's inflation... it looks like it's closer to $100 for everything. $15 for the strap, $6 each for the casters (rubber 3") $7 each for the 2x4's, $17 for the 2'x4' ply (15/32") $8 per box for the screws. and the rest in Msc Hardware.
Recognize!!!
In the early 60s, my dad built a small boat for my brother and me from Popular Science plans called "The 20 Buck Dinghy". As listed, all components required to build said boat was just under 20 dollars.
Today, that same materials package is over $400.
Re: Wing stand/rack
Postby Tony4aro » Sun Feb 20, 2022 7:05 pm
I got time to build my wing rack today. Took about 3rhs of non-rushed work. The PDF is great. Just cut out the parts, and screw it together. To keep from damaging the straps... use a hot nail to make holes. I used an old butane soldering iron to make holes. It was convenient and worked perfect. I also added D-rings to I could strap the wings on to the stand. Don't need them to fall off when rolling it around.
https://photos.app.goo.gl/U8J5d95bJfvgGWEk8
N3848D
W0181
Tony4aro
Return to Tools
