zzdeck wrote:Hi Todd. This is Dan Green. Got your message that you had he same thing. You said check this then there was no further information. Don’t know why. Could you re submit your info thanks Dan
Alternator stator epoxy potting cracked. I was getting a loud 'click' as each magnet crossed it pulling prop thru. Chucked it up in the lathe and took 0.020 off it. Some locals were worried the bigger gap would affect charging. I think only .005-0.010 actually came off metal parts before it was round and the crack lip disappeared. Seems to work fine. $400 saved if it holds up.
zzdeck wrote:Thanks Scott and Bryan! You both sent us down the right track. Our aerovee was assembled before we purchased it. The previous owner had hired a VW mechanic to assemble the engine. Don't know if the VW guy or the previous owner installed the stator. Regardless, after we removed the stator assembly plate we found that the stator screws were very loose, not even close to finger tight allowing the stator move around. We can only assume whoever installed it just forgot to tighten the bolts.
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
