Skippydiesel wrote:I would like to try and shorten some of the electrical cables, connecting modules etc, in my new Sonex.
If I cut/reduce the cables I will need to re connect the plugs to the shortened cable. I am absolutely certain I can achieve this with a little technical help.
I already have access to a 22 AWG 4 jaw crimping tool - so all I will need is the correct extract/insert tool and the correct male/female pin connectors.
The system is Dynon Skyview and I believe (not absolutely certain) that the plugs on each end of the overlength cables, are D-Sub type, with 2 rows of pins, totalling 9 connectors.
Can anyone advise me of the correct terminology & specifications (size pf pin connectors) so that I may purchase with confidence.
