About oil separators
Postby Sonex1517 » Sat Nov 27, 2021 10:44 pm
Re: About oil separators
Postby BRS » Sun Nov 28, 2021 12:37 am
I've been using the negative pressure system (https://antisplataero.com/products/cran ... t-complete) with a separator on my Sportsman for years. When rebuilding the ToolShed I installed the same system minus the separator. I figured the RevMaster will have much less blow-by than the lycoming and as such oil lost overboard would be minimal.
Perhaps those with AeroVee/other-VWs can clue me into how much blow-by they seem to experience. I've only have two flights on the RevMaster.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Postby Onex107 » Mon Nov 29, 2021 12:26 pm
I have a home made blow by catcher that is basically a one pint Ball Jar with a wad of stainless scrubber in the top covering the exhaust holes in the top. The ball jar lid is two piece so you can unscrew the lid and remove the jar without disturbing the tubing. The jar is also marked in ounces so I can measure the blow by which I think is another good way to measure your engines health. My engine has 350 hours on the hobbs and I normally see from 10 to 12 ounces in a 25 hour oil change. Not like the old quart in 10 that I experienced with the Cessna.
Postby GordonTurner » Mon Nov 29, 2021 3:40 pm
Mind attaching a picture? Interested to see the whole installation.
Thanks Gordon
Postby BRS » Mon Nov 29, 2021 10:31 pm
GordonTurner wrote:Mind attaching a picture? Interested to see the whole installation.
Thanks Gordon
which post are you asking pictures for?
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Postby mike.smith » Tue Nov 30, 2021 12:03 am
Construction and installation of my separator starts here:
http://www.mykitlog.com/users/display_l ... 73&row=107
The final assembly, minus the return line, is here:
http://www.mykitlog.com/users/display_l ... 13&row=101
Mine returns the oil to the engine via the valve cover. I've never found any evidence of "slime" going back to the engine. I have a clear return tube from the separator to the valve cover. I have a catch can so if anything gets past the separator it does not get dumped overboard. It also acts as a secondary outlet for crank case pressure if the separator return gets blocked. I only check the catch can during the annual condition inspection and have never found more than a few drops.
Postby BRS » Tue Nov 30, 2021 1:10 am
Mike,
That's very impressive.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Users browsing this forum: Google [Bot] and 122 guests
