Hey Lou,
Thanks for the info. Yeah that's about where I'm at with the lower cowl... I get the bottom edge around the gear legs and pushed all the way back, then I can push on the front hard enough to flex it into place behind the prop, then I do the bottom hinge pin followed by the two sides.
I think I can picture what you're talking about with the upper cowl. It would be so much easier if the cowl went on top of the windshield skirt! Then you could just drop it straight down.
Something like this?
![Image](https://cdn.nexternal.com/skybolt/images/jspn_DSC0293918.jpg)
Now that I'm thinking about it, I can probably still do what you're talking about without too much trouble. I could trace where the windshield skirt ends onto the cowl, cut the aft ~3/4" off of the cowl along that line, then rivet a strip along the bottom of the skirt, and then the cowl should sit on top of that.
I just already have all my Skybolt fasteners already set up, so I will have to try and drill out and reuse all the receptacles that I have on the aft edge of the cowl and move them to the new strip. I hope I can reuse them because I don't feel like waiting for more parts!!!
