mike.smith wrote:That's cheating!
WesRagle wrote:HI Guys,
Assuming you don't blast the sump, and ignoring the fact that my valve covers are hanging out in the wind, with the oil cooler cabin heat solution 100% of the thermal energy being extracted from the oil passes through the cockpit. Now, just like with the heat muff solution, it's a matter of balancing air flow with air temperature. But, you really don't have a choice with air flow. Since the primary function of the cooler is to cool the oil you have to accept whatever airflow is required to do that. The only way to change the airflow/air temperature equation is the change to a more/less efficient oil cooler.
Also, unlike the heat muff solution, there is a limited amount of heat available. It just happens to work out that the heat available is just enough.
So, it's just a matter of dumb luck that the oil cooler I chose and the amount of thermal energy available in the oil worked out to a satisfactory solution.
Concerning the heat muff solution, the problem faced is how to extract the heat from a near unlimited supply. Various techniques have been tried to increase the efficiency of heat muffs. The one that makes the most sense to me is modifying the muff by using a stretched out spring coiled around the exhaust pipe. You might pick up a little heat transfer from the spring but I believe the primary benefit would come from adding turbulence to the air flow. I don't know, I've never tested it.
One thing for sure, the pipes are hot. If you could keep the air in the muff longer (while maintaining a suitable flow rate) more heat would be transferred. The only way I see to do that is increase the diameter/volume of the muff. Since the typical muff designs aren't very "fat", and since a lot of the internal volume is taken up by the pipe itself, a small increase in diameter would double the volume of the muff thus keeping the air in the muff on average twice as long.
So, that's what I would try. Add some turbulence to the airflow through a muff of increased diameter.
Wes
The linear expiation coefficient of your magnesium engine case
is a issue. Iron is 10 aluminum is 21-24 mag is 25-26.5
The hotter the case temp the larger the main bearing bores become
and the strength of the case depreciates.
The oil temp represents the temprature of the case. We try to keep the
oil temp around 180 F or lower. Hot day climb outs included. The engine
is oil cooled as well as air cooled. Over the years our competitors have
run oil temps as high as 240F resulting in many negative issues including
damaged engine cases.
GordonTurner wrote:How is the oil cooling in the summer. Is the airflow through the cooler when the firewall valve is in “bypass” approximately the same as the normal oil cooler installation would experience? I am impressed by your setup for the heating in the winter end of the operation, but have you used it during the cooling in the summer end? Very nice fabrication.
WesRagle wrote:HI Guys,... I'm curious where oil temperature is measured on the RevMaster. ...Wes
Mark: Sorry that your thread got hijacked. It wasn't my intent.
Wes
Users browsing this forum: Google Adsense [Bot] and 5 guests
