Scott Todd wrote:But I don't think we should let the 1in10 or 1in30 number scare us out of one. There are a couple things to look at. First its a small sample size. If the size were two, the 1in2 chance looks REALLY bad. As the sample grows, 1in3, 1in4, etc, it still looks really bad. Granted 1in10 IS bad as kmacht points out but it should decline as the sample size grows. There is also an infant mortality thing at play here which kind of leads to the second thing to look at.
Well one thing folks should NOT read into this is that you have a 1 in 10 chance of having an accident every time you fly. This is about how well the fleet fares.
Infant mortality is a factor. But you could only get a comparison if you could compare to the same number of (different type of) aircraft in about the same time period to see who fared worse. To take it to it's extreme:
The longer you leave a fleet in being - the worse the fleet figure will get. I mean they built about 23,000 C150/2's starting 50 years ago. Keep it up for long enough and their figures will look horrible as a percentage of losses against aircraft built. I think there are about 8,000 left on US registry. And of course many just rotted away or were exported. That said the current accident attrition rate on C150/2's in the USA is about 2 a week.
If you read the narratives of probable cause in the spreadsheet - people are just not staying in control of the planes once distracted.
There are also a few - first flight and fatal. Let's face it - jumping into a plane it took you 4 years to build and short on any recent currency because you have been busy building is not a good thing.
Interesting point about the insurance broker. I got some traction with offering to do the Foundation transition training syllabus as part of my first 5 hours with a CFI (down from 10 with no syllabus). Once we had that out the way - the CFI and I spent a lot of time doing improbable turns at maximum gross at ever lower altitudes over a very quiet and large airport. Minimum Maneuvering Speed established at 60knots Indicated at 45-degree bank.
