Scott Todd wrote:The Aeroinjectors can be too rich at the low end....that fuel line looks pretty small. Is it gravity feed or is there a pump?
Scott Todd wrote:I have an MGL XTreme and one of the few things that bothers me is the slow response on some of the sensors. When leaning, I move the mixture and have to wait several seconds to see a change. Its a bit frustrating but workable. The fuel flow is about as bad.
Scott
pappas wrote:[snip]... the engine runs fine upon advance of throttle until just prior to WOT and then stumbles. If that happens, the manual tells us to limit the throttle's ability to advance just a bit prior to the symptom occurring.[snip]
Bryan Cotton wrote:Mine runs good at WOT. What am I doing wrong?
BRS wrote:Bryan Cotton wrote:Mine runs good at WOT. What am I doing wrong?
Your "what" runs good at WOT (32mm, 35mm, revflow)? Your signature indicates aerovee so I'm guessing you have a aeroinjector.
BRS wrote:Q: 32mm vs 35mm?
In the long run I'll likely purchase an AeroInjector. It seems to be more mature and better supported than what I have. But what size? The Revmaster R2300 is an 85HP rated engine and the RevFlow measures slightly larger than 35mm. However the AeroInjector comes as 32mm (30-90hp) and 35mm (90-125hp). Do you those of you, who know, think that the 35mm AeroInjector would cause issues with the R2300?
Users browsing this forum: No registered users and 36 guests
