MichaelFarley56 wrote:Unfortunately you won’t know unless you ask Peter, but with the reports I’m hearing, underwriters are apparently much more restrictive when it comes to similar time in type. So ask and hope but don’t be surprised if they say no.
Good luck!
MichaelFarley56 wrote:I don’t believe liability only has been as much of an issue, but others can hopefully chime in with more info.
Scott Todd wrote:Try NOT to let someone else fly off your test cards. It's part of the whole experience. Why would you let an instructor fly it? Are they insured? Look into additional pilot which would allow you to go during Phase 1. Once you get 10 hours of logged time, you should be able to get insurance. You can probably get liability only until you get the 10 hours or whatever they will require. Probably cheaper and better than paying someone to fly that time off.
There is no coverage in flight unless a Standard airworthiness certificate is in full force and effect.
Prior to solo, Ryan Young must successfully complete a minimum of 3 hours in a Sonex Waiex TRIGEAR, while accompanied by a FAA Certificated Flight Instructor who meets the conditions of the Open Pilot Clause. No Passenger coverage is provided while Ryan Young is at the controls of Sonex Waiex TRIGEAR N____ unless accompanied by an FAA Certificated Flight Instructor who meets the conditions of the Open Pilot Clause or a Designated Pilot Examiner until Ryan Young has completed the requirements shown above, has received proper FAA rating and or endorsements and has logged a minimum of 6 hours in a Sonex Waiex TRIGEAR.
Users browsing this forum: Google [Bot] and 104 guests
