Hello Everyone,
I know there's a lot of Sonex owners who have installed an MGL Xtreme EFIS and Sandia STX-165R and are having good luck with the combination. I have finished installing the Sandia into my Waiex to follow suit, but I'm running into a bit of an issue. Since I tend to be pretty stupid, I wanted to ask the collective wisdom of all of you to see if anyone has any advice on what I'm doing wrong!
I installed the Sandia transponder under the seat assembly and have everything ready to go, and went into the MGL Xtreme menu to activate the transponder, but I keep getting a little red X over the transponder status box on the main EFIS page. Has anyone else seen this? The transponder has power and ground, and the RS-232 TX/RX cables are correctly connected to the EFIS TX/RX cables. It should be fine but I can't get it to work!
Has anyone else seen the dreaded red X, and can offer suggestions on how to fix?
Thank you everyone!
![MGLTXPNDR.jpeg](./download/file.php?id=3859&sid=f9aff92040d51916b1703c1bc49271ee)
- MGLTXPNDR.jpeg (28.59 KiB) Viewed 3628 times
