HI Guys,
The pipes are now at the muffler shop to have the O2 bungs welded in.
While waiting on the pipes I needed to make sure the engine would run. The goal is to take this one step at a time. First step is to start the engine without changing anything. So, the first engine run will be with 100LL.
Hooked up the new battery and charged it.
Changed the oil and added some cam guard (better late than never).
Torqued the prop.
Checked the timing.
Checked the valve lash.
Pulled the plugs.
Crank until I had oil pressure + 10 seconds.
Replaced the plugs.
Ran fuel from the bench to the Sonerai and checked for and fix leaks.
Master on, Mag Hot, Throttle cracked, Mixture full rich, count 1 2 3, and Start.
After two years, the engine roared to life immediately. It scared me :-) I had the throttle a little bit too "cracked" and the canopy hit me in the head. So, I took the canopy off. That took all of 30 seconds. 15 of that was figuring out how to take it off.
I shut the engine down and started wiring. Since there is nothing more frustrating than fighting grounding problems, I started there.
I ran a ground from the engine block to the negative terminal of the battery. Then I ran a 12 gauge ground from the negative terminal of the battery over to the work bench. I have a handy little widget that plugs into a three prong outlet and provides two connections to safety ground. The entire setup will be grounded to the safety ground. Maybe I won't blow up any test equipment.
I made it as far as wiring the two secondary ignition leads and the P-Lead before I ran out of steam.
Oh yea, I also got an inexpensive 13.6 V (I think), 10 A power supply to power everything except the starter.
All of the signals will eventually get wired to terminal strips but I couldn't resist having a look at the P-Lead and low tension side of the secondary ignition. I've been thinking about those signals a long time. It was nice to finally meet them.
P-Lead pics:
Looks like about 150 Volts peak. Easy to see when the plug fires, and for how long.
Secondary Ign. pics:
I turned the peak picker on for the first pic of the secondary. The scope measured a peak voltage of 468 V. You can also see two distinct steps in the wave form. It's like one plug burned a lot longer than the other. Wonder if the wasted spark or the "real" spark burned longer.
There are a lot of questions that can be answered with a running engine. Like: How high would the voltages go if the plug never fired? The list is long but now I can start getting some answers. Great fun.
Forever Forward,
Wes
