B-model cooling exits
Postby Area 51% » Fri Aug 06, 2021 1:42 pm
Can someone give the dimensions and location of the cooling air exit holes on the B-model cowl? I'm about to try something else in the same location on a Legacy, but don't want to make my exits so large (or odd shaped) that the Bs vents won't fit if this experiment goes wrong.
Area 51%
Re: B-model cooling exits
Postby WesRagle » Fri Aug 06, 2021 4:08 pm
Hey Randy,
You have probably seen this but, if not, it might help some.: https://www.sonexaircraft.com/documents/plan_sheets/SNB-P16-06_NC_B-Model_Cowl_Vents.pdf.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby GraemeSmith » Fri Aug 06, 2021 5:19 pm
Randy:
I did post this - but have to stress that I posted it April 1st (some people missed that)
viewtopic.php?f=3&t=6159
Here are the "B style" vents I DID put in a Legacy cowl:
Mold made of waxed pine board
Lay up of epoxy and glass, aluminum tube to reinforce edge and curing under peel ply
Section after releasing from mold
Trimmed and epoxied in place over slot in cowl
Aluminum end plates epoxied in place
Outside - priming and filling
In Service - ignore crappy cowl paint.
I was trying this before I tried an opening cowl flap in the bottom of the cowl. Slots were a lot of work for a small gain. Wish I had tried a cowl flap first. I suspect it will be a lot more effective and can be stowed to streamline when not needed. That's next and I may even remove the B Vents if the cowl flap works better.
Graeme JW Smith
GraemeSmith
Postby Bryan Cotton » Fri Aug 06, 2021 6:10 pm
That looks a lot different.
Postby Area 51% » Fri Aug 06, 2021 6:31 pm
Thanks Wes, that's what I was looking for.
Graeme, it appears at one time there was another opening below your vertical vent. As I recall, the April Fools post showed what looked like marine vents. The witness marks under your B-ish vent looks to be just that.
What I have in hand are the Van's supplemental vents that, according to the installation sheet, get installed in the bottom of the lower cowl ahead of the normal opening in an RV. My intention is to install them in the sides where the B-vents will go if this turns out to be a bust. They are multiple gills as opposed to a single slot.
Thanks Group.
Wishing in one hand and shi--ing in the other here @Area 51%
Area 51%
Postby Kai » Sat Aug 07, 2021 3:24 am
I posted this on the actual flying Rotax thread as well.
The side outlets for my Legacy were more or less shaped according to a drawing that Kerry mailed a while back. Let me just say that in addition to the standard bottom exits, the improvement in cooling efficiency with the addition of the side outlets is massive!
Thanks
Kai
Sonex A #0525- SG, DS.
Kai
Users browsing this forum: Google [Bot] and 105 guests
