WesRagle wrote:HI Guys,
I'm curious. Are guys failing to pin the canopy closed? Or is the locator pin through the longeron failing?
What's going on here?
Wes
Area 51% wrote:I've discovered my locator pin missing on two occasions. Both during pre-flight. Not sure exactly when they went on walkabout. Locktite would be our friend if it weren't for the plexi. The current one is testing the tenacity of JB Weld.
Carlos Trigo wrote:But for your 2nd question, despite having
zero experience in Sonex flying, because I’m still building a XENOS- B, I would say, from the plans, that the locator pin doesn’t have anything to do with latching the canopy, and therefore no influence in the safety of the canopy in flight.
Am I wrong?
Simply - Yes. The locator pin gives the latches something to work against. Without the pins - the latches can push the canopy backwards and alongside the empennage and the latches never meaningfully engage.Carlos Trigo wrote:I would say, from the plans, that the locator pin doesn’t have anything to do with latching the canopy, and therefore no influence in the safety of the canopy in flight.
Am I wrong?
Carlos
WesRagle wrote:You're probably right. I'm just trying to imagine anything, other than failing to pin the canopy, that would cause the canopy to open in flight.
Talking about accidents can seem insensitive, and I don't want to be insensitive, but this has happened too many times causing several accidents. The tendency to forget only increases with the addition of the second "ventilation" hook.
Enough from me.
Wes
radfordc wrote:I decided early on in my Sonex experience that the canopy latch locking pin wouldn't be a great idea for me. Too easy to overlook, ignore, or lose the pin. I added a spring that kept the latch securely pulled forward into position. If the latch was secured properly the spring ensured that it would stay secured.
Area 51% wrote:My plans (Waiex 212 page D-02) include a spring for just that purpose. I thought all Sonex/Waiex/Xenos had it, but I guess it was added somewhere along the evolution of the kits even though there's no mention of it in either the service bulletins or drawing revisions that I could find.
Users browsing this forum: No registered users and 102 guests
