fastj22 wrote:One thing to really consider is a LRI (Lift Reserve Indicator or AOA). A few years back someone was selling these on the innertubes which is basically a HVAC filter gauge (differential pressure to tell you when to replace the filter) and custom inkjet printed card, plumbed to a 3D printed probe, mounted under the wing that measured the differential pressure from two sources. You calibrate by flying into a stall, land, adjust the probe, fly again into a stall, adjust the probe, repeat until it stalls right at the red line on the gauge. After that, if you keep it above the red, you won't be dead. No electrons (pixies), just air. Works at all airspeeds and density altitudes. Life saver. These fancy EFISs do the same thing, but require angry pixies to make it work. If you can find the guy who was making these its worth the $250 and when all the pixies fly away from you, you still have something to land with. And you will land much slower than you ever thought you could.
mike.smith wrote:The Sonex panel is limited, so electronic instruments go a long way to allowing you to put everything you want into your panel. I recommend you physically try the ones you are thinking of (like at Airventure), not just pick it based on the literature.
DCASonex wrote:Another two cents worth. I have a GRT EFIS. to which I have also added autopilot. The autopilot is unnecessary if just local fun flying, but turns a neutral stability Sonex that you have to FLY at all times into more comfortable cross country machine where you can sit back and watch the scenery and for traffic.
OtterlyFoolish wrote:That is two votes for the LRI. I really need to investigate this. Sounds like a good idea even if I get a display panel.
Bryan Cotton wrote:I have a simple EFIS in my Waiex and no attitude information. I am instrument rated. The Waiex is not the plane for that in my opinion. Plus weight is the enemy.
Rynoth wrote:I made a short video demonstrating an LRI in action
OtterlyFoolish wrote:I really only use the attitude indicator to confirm what I am seeing outside as far as angles go because I live near a lot of mountains and it can be deceptive at times looking straight ahead.
