Flat pattern for compass mount:
The most dangerous tool known to man:
Years ago a buddy make me these #6 flush screws with a 1/16" hole down the middle. I used them to locate holes on my hummelbird tank cover.
I used them to transfer holes from the compass to the part. Note the two drill bits sticking up are to keep alignment.
Ready to bend:
I have an 8' tennsmith. I didn't feel like taking the bicycle across the field to use the EAA pan and box brake. I did the first two bends on the tennsmith, then bent the two flanges with flanging pliers, and finally made a buck out of a 2x4 for the last bend.
I riveted it together and did a trial fit. I've figured out how I'll mount it to the windshield bow. The windshield is held on to the bow by #8 flush screws. The bow is solid, 1/2" diameter, and has a tapped hole drilled all the way through. I've ordered some longer flush brass screws. I'll replace the middle steel flush screw with a longer brass one. There is a hole in the top of the bracket, and the longer screw will stick out like a stud. Then I can put a nut on it to hold the compass. Plus I'll make a bracket to tie it to the canopy sealing surface.
