AeroVee Turbo allows a factory approved gross weight of 1,200lb Up from 1,100 of the non-turbo.
In most cases, a nicely equipped Sonex will end up weighing around 700 lbs which gives you a useful load of around 500 lbs.
daleandee wrote:Can someone give some clarification please?
GraemeSmith stated:AeroVee Turbo allows a factory approved gross weight of 1,200lb Up from 1,100 of the non-turbo.
MichaelFarley56 stated:In most cases, a nicely equipped Sonex will end up weighing around 700 lbs which gives you a useful load of around 500 lbs.
Has the factory approved a gross weight change for Sonex aircraft? I cannot find a confirmation anywhere ...
Dale
pappas wrote:John must hate these discussions because he doesn't really want anything other than an altimeter, oil-pressure gauge, and an air-speed indicator in these things.
Don't get me wrong. I am not even remotely suggesting that any Sonex in the lineup is a good IFR platform. They are not. I would never decide to intentionally fly one as my primary aircraft if I needed to fly often in IMC.
I am only stating that it is nice to have modern, lightweight, glass panel equipment with very full-featured VFR capabilities. In the event that I found that I had planned so poorly, which I have not yet in 30 years of flying, that I was about to run out of fuel over Carlsbad and needed to get through a 300 ft layer of light overcast to break-out with a clear 900 feet left above the runway, I would rather have the set-up I have than not.
builderflyer wrote:It must be frustrating for an aircraft designer to design an aircraft with a particular mission in mind only to have it being utilized for missions that the designer had not anticipated, or even considered reasonable. VanGrunsven went through this dilemma years ago with the RV-6 and I have to wonder what John Monnett may be thinking if he's been reading any of these recent messages.
builderflyer wrote:Regarding instrument flying competency. ........there is no instrument rating lite.........flying 2 or 3 instrument departures or approaches a year through a relatively thin marine layer does not begin to keep an keep an instrument pilot current, legally or otherwise. Not that it is impossible, but it takes a very dedicated private pilot to retain the level of instrument proficiency once achieved at the time of receiving the rating and must be maintained as the years go on. When no longer required as a condition of our employment, many of us have chosen to allow this rating to lapse simply because of the difficulty in maintaining currency.
pappas wrote:With all of that said, It is a testament to the versatility of the Sonex design. John designed it to fulfill his vision. But he designed it so well that it is capable of more. There is no denying that these things have flown almost everywhere. Use it for a one hour fun machine twice a week if you like it that way. Fly it all across your region of the country if you like to travel alone and have places you want to see. 145 mph, less than 6 gph burn, no speeding tickets, beats the hell out of driving in my opinion.
pappas wrote:My Waiex B has the Aerovee Turbo up front. I have all Dynon avionics including a Dynon 10 inch HDX, AutoPilot, A/P Expert panel, Baro/Alt/Hdg/Trk Knob Panel, Intercom, Comm Radio, Xponder, ADSB in and out. I run an IPad Mini on the right side of the panel. I don't think all of this stuff weighs 15 pounds, I could be wrong, but not by much.
The Scottsdale FSDO sent out 2 inspectors for my airworthiness inspection prior to the first flight. They took about 2 hours going over the plane. I showed him how all of the avionics worked and he said, "I'm going to sign this plane off for IFR flight". It didn't occur to me to ask him for that, he just announced he would. So......my Waiex is ready for a marine layer. Go Figure!
Users browsing this forum: Google [Bot] and 104 guests
