Bryan Cotton wrote:I sat in the airplane in the dark, and tried many orientations of a red LED. Nothing from the top or side made it legible. So, I'm not sure that setup would work.
I'm curious why you went with green instead of red.
Maybe what could work would be like a camping head lamp, but on a longer strap and wrapped around your chest instead of your head. Oh, even better maybe, if you found one on a clip you could just clip it to your shoulder strap at the right height. Then it would be more directly aiming at the panel and wouldn't reflect off the inside of the canopy from whichever direction you look, like a headlamp would.
I did green only because that's what I'm used to at work ;)
![maxresdefault.jpg](./download/file.php?id=3438&sid=dcedfe764e17019ab9979eea7a85ab6e)
- maxresdefault.jpg (244.57 KiB) Viewed 6118 times
Although I will probably not fly the Waiex with NVG's on so I guess it doesn't really matter
