Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby n307tw » Sun Feb 21, 2021 11:09 am
Bryan Cotton wrote:Flying to Oshkosh next year is my goal! Same as the last 5 years.
I chuckled because I have been saying this for 2 years now. Keep up the great work!
Tim Wrede
Long Island, NY
Sonex-B #18, Nosedragger
Aeromomentum AM15, Garmin G3X
My Build Site
n307tw
Postby Bryan Cotton » Sun Feb 21, 2021 9:02 pm
I made my own adel style clamp and riveted it to the TC mount. A flush #6 screw gives another attach point and clamps it to the tube.
Top view mounted. Note the dimple and rivet tail are in a spot where the connectors allow some clearance.
Bottom view. I used a metal stop nut and countersunk a small 1/8" shim for the dimples.
The top gang of 4 are for CHTs. The bottom will be EGTs. I swapped the male-female connector definition between the two.
Postby Sonex1517 » Sun Feb 21, 2021 9:31 pm
Lookin’ good Bryan!
You may be ready for Oshkosh!
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Postby Bryan Cotton » Sun Feb 21, 2021 9:51 pm
Sonex1517 wrote:Lookin’ good Bryan!
Thanks Robbie! Did I mention my goal is to fly to Oshkosh this year?
Postby Sonex1517 » Sun Feb 21, 2021 10:52 pm
Maaaaaybe.....but I figure if we all harass you then you may actually do it!
Aero Estates (T25)
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Postby Bryan Cotton » Fri Feb 26, 2021 11:34 am
CHT on top, EGT on bottom.
CHTs are done. I've started the engine side EGTs.
I've fabricated my com and transponder antenna cables. My nav cable is terminated at the radio end and cut to rough length currently.
Postby jjbardell » Fri Feb 26, 2021 2:48 pm
Looking good!
One thing you may want to consider is putting a protection layer between your clamps / zip ties, etc. and your engine mount. Zip ties have glass/abrasive material in them, and raw metal and will wear through the paint and expose the mount, resulting in corrosion risk. Personally, I don't use zip ties anymore and use lacing string now.
Lacing string: https://www.aircraftspruce.com/catalog/ ... gTapes.php
N83LJ - Sonex #0864 (SOLD)
jjbardell
Postby Scott Todd » Fri Feb 26, 2021 11:07 pm
I've heard that about zip ties before. When I built my Kitfox 23 years ago, I didn't know better and used them. Several people have seen them and told me I shouldn't use them. So I decided to turn it into an experiment. After all, it says so right inside the cockpit in big 2" letters. I move them gently and look every year at condition. I have yet to see ant wear marks in the powder coating, on the hoses, or wires. I think 1 or 2 have broken off over the years and been replaced. Your mileage may vary but I've never seen them wear into anything. If they are, you may have some vibration issues that need to be addressed.
Scott Todd
Postby Bryan Cotton » Sat Feb 27, 2021 9:56 am
I've actually seen Sikorsky go back and forth on tie string vs tie wraps on the Blackhawks. They do use a lot of tie wraps. I was considering string just due to the heat, but I have the zip ties in my box. I have been thinking about getting a roll of string however.
Postby Bryan Cotton » Sat Feb 27, 2021 4:18 pm
Return to Photo Album
Users browsing this forum: Google [Bot] and 23 guests
