Roll rate
Roll rate
Postby fastj22 » Sun Nov 10, 2013 10:16 pm
I have the aerobatic aileron modification on my Waiex and always wondered what the roll rate would be. I posted a video to show it. Pretty impressive.
I entered each roll at 125 MPH indicated and did a full deflection throughout the roll.
http://youtu.be/lLEz-lC6NPk
Re: Roll rate
Postby Bryan Cotton » Mon Nov 11, 2013 8:28 am
Looks like about 120 degrees per second, or a little better. Pretty good! What do the stock ailerons do?
Re: Roll rate
Postby radfordc » Wed Nov 13, 2013 11:17 pm
radfordc
Roll rate
Postby sonex 1614 » Thu Nov 14, 2013 2:04 am
Does it handle noticeably different in level flight? I have been curious to know if it becomes a handful on a cross country flight with the larger ailerons. Also, how does it feel with the smaller flaps? Is the stall speed noticeably higher?
Thanks In advance!
Tony
Sonex 1614
Chicago Area
sonex 1614
Re: Roll rate
Postby Bryan Cotton » Thu Nov 14, 2013 2:26 pm
For the acro ailerons I timed 2.83 seconds and for the regular ailerons 4.2 seconds. That is 127 vs 85 degrees per second. Those measurements are somewhat rough.
Roll rate
Postby Sonerai13 » Thu Nov 14, 2013 3:06 pm
There isn't a dramatic difference in handling due to the reduced flap area. The flaps are still very effective. The difference in full-flap stall speed is minimal, to the point of being almost undetectable in normal operations.
If I were building a Sonex for myself, aerobat ailerons would be a must. :)
Cheers!
Joe
"Fortes Fortuna Adiuvat"
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Sonerai13
Re: Roll rate
Postby radfordc » Thu Nov 14, 2013 6:01 pm
Bryan Cotton wrote:For the acro ailerons I timed 2.83 seconds and for the regular ailerons 4.2 seconds. That is 127 vs 85 degrees per second. Those measurements are somewhat rough.
Pilot technique may also be a factor. I doubt I was getting all the roll performance possible from my plane.
radfordc
Re: Roll rate
Postby fastj22 » Fri Nov 15, 2013 12:54 am
Agreed, I'm an upside down rookie. I entered the roll at @ 125mph ias pulled up slightly and did a full deflection and held through the roll. To compare to the standard aileron, we would need someone with them to do the exact same. Not sure it Charlie did that.
I will say that having the big ailerons does not make the plane twitchy, the smaller flaps do not impact my landings. I can land as slow as any other sonex. I'm glad I chose them,
