AN363 vs AN365
AN363 vs AN365
Postby pfhoeycfi » Sun Sep 20, 2020 11:25 am
I am curious if AN363 are preferable over AN365 firewall forward?
peter
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: AN363 vs AN365
Postby Rynoth » Sun Sep 20, 2020 12:16 pm
I used the AN363 where they're called for in the plans, which is basically everything structural (engine mount.) I have a lot of AN365 FWF on things like adel clamps, air filter and firewall-mounted accessories. I've never seen any signs of heat affecting/compromising them. The 2 downsides I see to AN363 are 1) they are harder to turn, and 2) I believe they may scratch the bolt a bit if moved/removed somewhat frequently, such as the air filter or prop hub.
Re: AN363 vs AN365
Postby Gordon » Mon Sep 21, 2020 9:09 am
AN363 nuts.............?
Don't use AN365 fiber lock nuts forward of the firewall. The heat will deteriorate the locking effect after a time.
All nuts in the engine compartment should be AN363 lock nuts OR AN310 castle nuts with a cotter pin.
In Canada the MD-RA inspector (final inspection before flight) will "snag" you for any AN365 nuts firewall fwd and make you change them to AN363's.
Gordon.......Hummel 2400......Onex #0024....C-IODB
Gordon
Re: AN363 vs AN365
Postby Sonerai13 » Mon Sep 21, 2020 10:11 am
I agree with Gordon - don't use any fiber-lock nuts in the engine compartment. It may not appear that they are being affected by the heat, but I have found that, over time they will ultimately lose their locking ability. Use all-metal locking nuts, or castle nuts with cotter pins, in the engine compartment. You'll be glad you did!
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Fortes Fortuna Adiuvat
Sonerai13
Re: AN363 vs AN365
Postby pfhoeycfi » Mon Sep 21, 2020 12:41 pm
Sonerai13 wrote:I agree with Gordon - don't use any fiber-lock nuts in the engine compartment. It may not appear that they are being affected by the heat, but I have found that, over time they will ultimately lose their locking ability. Use all-metal locking nuts, or castle nuts with cotter pins, in the engine compartment. You'll be glad you did!
ok good info...
Would it also be a good idea to use loctite 242 (or other??) with the AN363s?
Thanks everybody...
peter
Peter Hoey
pfhoeycfi
Re: AN363 vs AN365
Postby Sonerai13 » Mon Sep 21, 2020 12:45 pm
No need for loctite. Besides, it is affected by heat as well, so wouldn't really do anything. Let the nuts do their job.
Joe Norris
Sonerai13
Re: AN363 vs AN365
Postby pfhoeycfi » Mon Sep 21, 2020 12:47 pm
ok thanks...
peter
Peter Hoey
pfhoeycfi
Re: AN363 vs AN365
Postby Spaceman » Wed Jan 06, 2021 7:47 am
The whole Aerovee engine case is held together with nylon locknuts, so how is that acceptable there but not on other components on the firewall, etc?
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Re: AN363 vs AN365
Postby jeff0196 » Wed Jan 06, 2021 9:27 am
The nylocks on the engine are not there for locking. The idea of the nylock on a vw has been around for a long time. Regular threads have a helical shaped “leak” path that allows the studs on a vw case to leak oil over time. The nylock is there to seal the leak path and prevent oil leaks at the studs. Their locking ability is not intended to mean anything to engine function.
Jeffrey W
Waiex 0196
AeroVee Turbo
jeff0196
Re: AN363 vs AN365
Postby Spaceman » Wed Jan 06, 2021 10:17 pm
Ah, I wouldn't have guessed that! Thanks!
Chris Paegelow
Spaceman
Users browsing this forum: dreyn96 and 12 guests
