ONEX tri gear
ONEX tri gear
Postby onex28 » Thu Jul 28, 2011 11:29 am
I have a photo of the tri gear Onex but it is too large to post. Can someone tell me how to reduce it below 256 KB. If I can't reduce it I will try to take another photo Friday. Lots of rain and mist here last two days but we are still having fun!
onex28
Uploading Pictures Tutorial
Postby chris » Thu Jul 28, 2011 12:15 pm
Here is the method I use to quickly resize pictures for posting when I do not have access to photo editing software. There are several ways to do it but I find that this is one of the easiest.
A big advantage to doing this to post photos is that they do not take up space on the sonexbuilders.net server. They are hosted by another free image hosting website. I'm not trying to endorse one specific site, but I use it and am familiar so here is a quick tutorial for posting images.
1. Go to http://imageshack.us/
2. Upload your file at 800 x 600, 640 x 480, or 320 x 240. 800 x 600 is the default resize. 640 x 480 is probably the best size for posting.
3. It will then give you several links that can be used for copying and pasting.
4. Copy the text in the box beside of "Forum Code" and paste it in your post.
5. This is the code that will be pasted:
Code: Select all
[URL=http://imageshack.us/photo/my-images/580/img20110721065152.jpg/][IMG]http://img580.imageshack.us/img580/5574/img20110721065152.jpg[/IMG][/URL]
Uploaded with [URL=http://imageshack.us]ImageShack.us[/URL]
6. If you do not want to have links to imageshack delete everything except this:
Code: Select all
7. Final Result 800 x 600:
8. Final Result 640 x 480:
Chris
Sonex 1409
Slowly Scratch Building
Site Owner/Admin
chris
Site Admin
Re: ONEX tri gear
Postby onex28 » Thu Jul 28, 2011 5:58 pm
Thanks for your help Chris, I've tried this site, let's see if it works. http://imageshack.us/photo/my-images/69 ... 277wq.jpg/
Edit by Chris: I fixed it for you. You almost had it. Just have to put the Img tags around it and get the url from the text box beside "forum code" instead of the one beside of "link"
onex28
Re: ONEX tri gear
Postby MichaelFarley56 » Thu Jul 28, 2011 6:38 pm
The Onex looks great! I can really see the tri gear becoming really popular for a lot of people. I'll be honest and say I haven't been the biggest fan of the looks of the tri gear Sonex but the Onex looks pretty good! Looks like it's getting close to finished too...
Waiex #0056 - N569KM
Jabiru 3300A #1706
Re: ONEX tri gear
Postby Mike53 » Thu Jul 28, 2011 9:21 pm
Thanks for the tri gear pic Mike.You just made up my mind on the gear I'll be ordering.
Mike
Mike
Antoine de Saint-Exupery
Mike53
Re: ONEX tri gear
Postby Andy Walker » Fri Jul 29, 2011 9:54 am
Wow, those fiberglass wingtips are HUGE.
Andy Walker
Re: ONEX tri gear
Postby radfordc » Fri Jul 29, 2011 11:21 am
Andy Walker wrote:Wow, those fiberglass wingtips are HUGE.
Wingtips...or white paint?
radfordc
Re: ONEX tri gear
Postby MichaelFarley56 » Fri Jul 29, 2011 12:43 pm
I believe those are fiberglass wing extensions to provide additional wing area for slower stalls. I think I read about them on the same post when Sonex was talking about raising the canopy.
If I'm mistaken, someone please correct me...
Jabiru 3300A #1706
Re: ONEX tri gear
Postby onex28 » Sat Jul 30, 2011 12:09 am
The larger wing tips give the Onex 84.4 sq. ft. of wing area to accomadate larger pilots and maintain LSA stall speeds. The option is there for a builder to build the 78 sq. ft. wing, which I plan to do as I'm not 250 lbs and I will still be within LSA parameters. I supposed one could cut the wingtip to achieve any sq. ft. number between 84.4 and 78.
onex28
Re: ONEX tri gear
Postby Sonex1517 » Mon Aug 01, 2011 9:06 pm
different angle...
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Return to Onex
Users browsing this forum: Bing [Bot] and 31 guests
