Finally
Post stories/images of the first flight of your Sonex, Waiex, Xenos, or Onex here.
Re: Finally
Postby n307tw » Tue Dec 22, 2020 11:27 pm
Been watching your posts for a while and so happy you got it in the air. Congratulations!!
Tim Wrede
Long Island, NY
Sonex-B #18, Nosedragger
Aeromomentum AM15, Garmin G3X
My Build Site
n307tw
Re: Finally
Postby Area 51% » Sat Nov 25, 2023 11:39 am
"Chett" was sold to a lad who works for Piper Aircraft about a year and a half ago. Sans engine. He didn't want the Aeroveeish anyway as he had plans to install a Continental O-200.
Regular updates from him showed that it was more than a pipe-dream and the perpetrator had some real talent in the engineering and fabrication fields.
Thanksgiving morning I received a note from Doug proclaiming "Chett" (now known as the "Skunk Ape") once again has won the battle against gravity proving it is possible if not sanctioned.
The early numbers show CHTs below 300deg, oil temps stable at 190, and 135kts at 2400rpm.
For those of you who do not know..........the Skunk Ape is Florida's version of Bigfoot. A largely mythical creature that has been discussed at length, searched for in earnest, but until recently, has never been actually seen in real life.
Welcome all to the Planet of the Apes.
Randy
Area 51%
Re: Finally
Postby LibelleDoug » Sat Dec 02, 2023 11:21 am
Thanks for the kind words Randy. The Skunk Ape is a sweet airplane, I look forward to continued adventures with it.
LibelleDoug
Re: Finally
Postby WaiexN143NM » Sat Dec 02, 2023 1:00 pm
hi doug
great job on the conversion. looks great!
michael.
WaiexN143NM
Re: Finally
Postby MichaelFarley56 » Sun Dec 03, 2023 12:03 pm
The Waiex looks great! I’d love to see more pictures of the firewall forward someday.
Great work!
Waiex #0056 - N569KM
Jabiru 3300A #1706
Re: Finally
Postby Bryan Cotton » Sun Dec 03, 2023 12:39 pm
Welcome to the forum! I am also interested to hear and see more.
Re: Finally
Postby LibelleDoug » Mon Dec 04, 2023 1:48 pm
To avoid multiple PM replys, here's an early synopsis:
I don't have any ambitions of making more mounts or cowls. Both were fabbed 'in situ" with minimal tooling or fixturing.
The prop hub is in the per-plans location in both Station and Waterline.
My O-200A is an experimental build with higher compression pistons.
The prop is a Sensenich 58 x 67. With the Tracy O'Brien steel gear legs (which are stiffer than Ti) and 5.00x5 tires it is almost exactly the 9" level prop clearance that Part 23 requires for certified airplanes. Both of my 2 landings so far have been relatively fast wheel landings (biz jet traffic behind me and tower requesting for max speed on final) without issue. The certified O-200a redline is 2750, and mine seems to turn 2800 level and WOT indicating 150 kts, so it seems that Steve at Senenich got the prop near-perfect. The prop has the Sonex tapered hub shape for the billet skullcap spinner, but the O-200A without a prop extension is so blunt up front that it worked out better to hide it behind a Vans FP13 spinner. I have not made any attempt to measure pitot/static position error yet so don't get too excited about airspeed. Takeoff and climbout at sub-1,000 lb solo weight is a grin-inducing deck angle without trying.
The exhaust is a used stainless 4 into 2 pair off a Zenith 601XL, and the carb heat/air filter box is Cessna 150.
It weighed 693 lbs on calibrated, certified aircraft scales with full oil and wheel pants and leg fairings installed. However, to get to the forward limit with full fuel and just me in the seat, I had to add 12 lb total (sum of ballast + a small radio battery) in the crotch of the V-tail. So it may as well be 705 empty.
It has no starter or alternator. A small B&C alternator would fit if desired but a starter will not.
For most builders, similar performance can probably be had with a Rotax 912S on factory mount, or Corvair on SPA mount. I am happy with the result of this build, but it is not a marketable product, just my personal vision.
Happy building and flying. -Doug
LibelleDoug
Re: Finally
Postby LibelleDoug » Mon Dec 04, 2023 1:59 pm
I have deleted this engine installation photo montage, due to uncomfortable PM's asking for detailed drawings, parts, and engineering advice. I'm not in that business.
Happy experimenting, building, and flying everyone.
LibelleDoug
Re: Finally
Postby BRS » Mon Dec 04, 2023 6:19 pm
Thanks for sharing the pictures in progress.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Re: Finally
Postby LibelleDoug » Mon May 13, 2024 6:23 pm
The Skunk Ape in white. I actually began polishing it in February, but by the time I finished the second wing, the first had corrosion speckles on the top already. So with 3 weekends invested, I cut my losses and concluded polishing is for retired people with sanitary airpark hangars, and had a hangar mate that used to paint cars paint it for me. A coat of epoxy primer and two coats of single stage urethane gave a satisfactory result, at the cost of 19 precious lbs. The weight of the paint doesn't seem to hamper the grin-inducing initial climb angle!
LibelleDoug
Return to First Flights!
