echo ADSB install question
Postby ncsonex » Thu Nov 26, 2020 8:23 pm
Has anyone installed the ECHO in a Sonex? Instructions would be helpful!
- Larry Long
Sonex TD
441.0 Hrs.
1077
ncsonex
Re: echo ADSB install question
Postby GraemeSmith » Thu Nov 26, 2020 10:16 pm
echoUAT?
Download the install instructions from uAvionix web site.
I put the unit two braces back down inside the empennage. (First brace has the magnetometer.) Straight UP to the empennage for the SkyFy antenna hockey puck on the outside (using a redundant hole - which drove part of the decision). Straight down and into the corner with a short co-ax to put the antenna outside - this got it as far away from the transponder antenna as I could get it. Power wires back to the buss and included it in the avionics switch so it boots when you turn on the avionics.
Graeme JW Smith
GraemeSmith
Postby Sonex1517 » Thu Nov 26, 2020 10:21 pm
I have, and it was an easy install. You can read about it here
http://www.sonexfoundation.com/uploads/ ... pdf#page15
I put the echo under the seat of my legacy Sonex and the antenna under the baggage bay. The GPS antenna is on top of my instrument panel.
I have a Garmin GTX-327 transponder and passed the ADS-B out check with little additional effort. I did have to make a slight adjustment in the echo, using the app, to meet specs.
If you have questions PM me.
Postby mike.smith » Thu Nov 26, 2020 11:53 pm
My install starting here:
http://www.mykitlog.com/users/display_l ... 9578&row=4
7 hours total time to install.
Postby pilotyoung » Fri Nov 27, 2020 1:01 am
I just installed the echoUAT and SkyFYX gps about a month ago I mounted the echoUAT on the side of the fuselage in the area to the left of the control stick. I mounted the GPS on top of the panel. It took me three tries to get it configured correctly but once configured, it is working great. It provides ADS-B out and ADS-B in on an iPad, iPhone, android phone or tablet or on an EFIS. I am using an iPad for ADS-B in.
pilotyoung
Postby badaero » Fri Nov 27, 2020 12:49 pm
Ditto sonex1517. using android phone with avare to monitor.
Bruce
Bruce Drinnen
M'boro,TN
720SX
"Money can't buy happiness but it can buy airplanes and bacon!"
badaero
Return to Electrical System
