sonex1566 wrote:Ooohh boy! This is where you get to decide on your level of courage! If I was forced to make a decision like that I would want to physically hold the bits in my hands and work out how much room was needed. My metal working skills are limited to a 'Harbour Freight' type milling machine and lathe. I can tell you I would have to be getting pretty desperate to want to tackle it. I'd recommend trying to have a look at the back of an engine to see how everything slots together. The ignition pickups and charging stator are a neat fit. I would imagine if the Great Plains alternator puts out more power it would have to be larger, either in depth or diameter. I suppose my main query would be as to how much stuff do you want to install? The modern glass screens are pretty efficient, maybe if you could work backwards and workout your total power needs and then decide whether to panic or not. The Jabiru engines put out about the same. The Camit, if there are any around put out more but they're not manufactured anymore. I haven't a foggiest about the Rotax engines. Good luck.
Users browsing this forum: dreyn96 and 20 guests
