racaldwell wrote:Carlos,
I would run the TE, pitot & static lines into the cockpit area lower than spec'ed on the plans. I drilled the holes per plans & those tubes come in where you can see them. I would rather have them low so the seat cushion hides them. Mine go low from the cockpit rear to pass under the spar at the sidewall. These tubes are very visible on the right side in the cockpit. A cockpit panel would cover them up but I didn't plan to install one.
Rick Caldwell
Xenos 0057
GordonTurner wrote:Don’t rivet the bottom skin on...pretty much until the day of your inspection.
Users browsing this forum: No registered users and 133 guests
