Panel Files (dwg and pdf)
Postby chris » Thu May 01, 2014 10:16 am
The folks at Sonex Aircraft were kind enough to make these files available to help with panel layouts.
ONX-E01_Instrument_Panel_Layout_Only.pdf
Onex PDF
(79.96 KiB) Downloaded 657 times
ONX-E01_Instrument_Panel_La.dwg
Onex DWG
(315.9 KiB) Downloaded 485 times
SNX-E01_Instrument_Panel_Layout_Only.pdf
Sonex PDF
(133.87 KiB) Downloaded 833 times
SNX-E01_Instrument_Panel_La.dwg
Sonex DWG
(294.08 KiB) Downloaded 678 times
Chris
Sonex 1409
Slowly Scratch Building
Site Owner/Admin
chris
Site Admin
Re: Panel Files (dwg and pdf)
Postby lakespookie » Wed Oct 14, 2020 11:49 pm
Wish someone had the dementions for the B model
Jill's Build Log
PPL-ASEL
Tail = Complete
Wings Closed Out = 02/04/2024
Waiex-B 0054
Panel G3X
lakespookie
Postby jrs » Thu Oct 15, 2020 11:16 am
sonex panel2.pdf
(460.75 KiB) Downloaded 350 times
I have those in visio.
jrs
Postby jrs » Thu Oct 15, 2020 11:19 am
sonex panel.pdf
(394.58 KiB) Downloaded 304 times
Cleaner version. I have been using Microsoft Visio and can save the output in a variety of formats. Have very little to contribute to the forum so glad to add this.
jrs
Postby jrs » Fri Oct 16, 2020 1:37 pm
Sorry for the stumbles. I'll try this again. I cleaned up the files and added a dwg.
Didn't have any practice in saving file as pdf or dwg so stumbled. These may be more useful. I don't us dwg and have no idea what is in the file. I can save the visio to it but can't see the contents. I hand drew the panel outline and it is to scale. The grid is 1/2". Hope that it is useful. Visio is handy if you have it on the PC. Has a learning curve but a tool from my previous life. There should be three attachments 1st outline with dimensions, 2nd outline with what my current thinking for layout is, 3rd the dwg file which I suspect contains all of my elements.
sonex panel2.pdf
(433.89 KiB) Downloaded 355 times
sonex panel.dwg
(54.21 KiB) Downloaded 326 times
sonex panel.pdf
(198.27 KiB) Downloaded 323 times
jrs
Postby Rofomoto » Fri Oct 16, 2020 2:59 pm
jrs wrote:Sorry for the stumbles. I'll try this again. I cleaned up the files and added a dwg.
sonex panel2.pdf
sonex panel.dwg
sonex panel.pdf
Don’t forget flap circuit. !
1735
Longassproject
Rofomoto
Postby jrs » Fri Oct 16, 2020 4:42 pm
Thanks for the input but I actually didn't forget. I had flap switch, trim knob, and MGL radio head in a pervious version. Put it together and set aside for a while. My current thinking is to use an A style trim lever mounted on the side panel and the flap switch in the stick. I ordered the wooden grips with push to talk button and a hat switch that should work. When you look at the iEFIS functions don't see why I would need the radio head. Nice to be able to remodel on the computer versus the band saw. If anyone is interested I also have some highly specialized MGL screen 8 and 9 files that I'm happy to share.
jrs
Postby jrs » Wed Oct 27, 2021 10:26 am
Someone asked for my visio file and I tried to upload it but is too large to post. Anyone that wants the source file give me an email address to sent to and I will get it to you.
jrs
Postby new_flyer » Wed Oct 27, 2021 3:46 pm
jrs wrote:Someone asked for my visio file and I tried to upload it but is too large to post. Anyone that wants the source file give me an email address to sent to and I will get it to you.
I sent you a PM.
new_flyer
Return to Panel
